'94 Camry turns over but won't start
my 94 camry starts but wont turn over need help had been working on it for a month
How can it start if it won't turn over? Kindly clarify.
Re: 95 Camry 4cyl - No spark
i have the same thing going on with my 94 camry truns but wont fire up is her something that tells the comupter not to send power to the distributer
Jamal,
Have you read the 22 previous posts on this thread? First determine if there is spark at the plug. |
no spak no power being sent to the distributor everything has power my father in law was helping me out we looked over everthing ove r an over when i got it i was told it was juast the timing belt but come to found out it was ok an the coil in the disributor was bad put i new one on still no spark is it the computer
If there is no power to the distributor, check the 12 v wire to the distributor for continuity.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
just put a computer on it wont didn`t help
how do i now if the wire is good or not good could be something else need help
if i fix the wire and it still wont work what else could be is there something stoping the computer to send power to the distributor
I suggest you get "Professional Help".
Re: '94 Camry turns over but won't start
I separated this into a different thread since you have a different model year and the previous thread had a resolution.
The most typical culprit is a weak ignition coil. It can give a spark and when tested with an ohmmeter it will barely pass, but the spark is too weak to ignite. If this is it, I'd recommend replacing with a Toyota coil...aftermarket ones don't last. The second common culprit is a faulty coolant temperature sensor. The third culprit is also in the distributor, called a condenser...a little barrel-shaped part connected to the left-side ignition coil. If the insulator looks melted, it's probably cooked. Post back if you find the solution.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
still have ? not spark theres no power to distributer still don`t know wat is stoping the it fromfireing up
The RustBuster i did everything u said checked it all over again i think it could be a wire gone bad anybody can help
Then I would check the 30A AM2 fuse located in the fuse box #2 in the engine compartment along the driver's side. After that, check the igniter for proper ground and operation, also on the driver's side near the firewall, mounted to the inner fender and next to the air filter box.
checked all the fuse all have good ground, but stil cant get it everthing has but tthose to things no power to dis so theres no spark
