p0300 mult cylinder misfire....
I have an 03 1500 silverado, 125000 miles, 5.3V8..... this morning once started it ran real rough, erratic idle, my check engine light flickered many times, but didnt stay on. I checked the codes after driving 25 miles and it had a p0300...which looks like multiple cylinder random misfire......so what to do? Plus are ac delco iridiums, changed about 50,000miles ago, new wires then as well.....
Re: p0300 mult cylinder misfire....
need scan tool to reset this code . engine running poorly will create this code as the cam gets jolted .. |
Random misfires on random cylinders -
Air - MAF sensor, EGR system, PCV system, and Air Intake system. Fuel - Fuel filter, fuel pump, flaky fuel pump relay. Exhaust - A plugged catalytic converter can cause random misfires. Ignition system - Crank sensor, and cam sensors. |
I did have a full tank of gas, will have to get a fuel pressure kit and see what I get. I almost wish the engine stays running rough so I know its fixed. I had to jump my truck this morning due to the extreme cold, could that make it run rough? |
correct the battery/cable power issues first. check the alternator for proper output. have battery load tested. then check the fuel pressures.. with the vehicle sitting it may show good pressure . driving may cause the pressure to drop out ... this is common. voltage to the fuel pump [pump relay] also power and ground connections to the / of the fuel pump. even fuses improperly removed causing loose sockets can create problems .. |
Ok update....cleared the p0300 code last week and stayed away...yesterday light back on, now getting p0174 and p0171.....truck appears to be running ok.... I read somewhere that these codes are related to the initial p0300 code.....I checked fuel pressure and get 50/51 at idle and around 53 when I rev the motor...
intake............
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
I was afraid of that, had read it was common to have that problem....any way to test/check for sure? I heard spraying around intake and looking for bubbles? Would i need to replace to the entire intake with the newer redesigned, or just the gasket? |
I get about 51psi max 54psi fuel pressure when revving motor...that seems low relative to what you mentioned jcat? |
your problem of intemittent running poorly is not a gasket leak.. gaskets that have failed are a constant..a motor / electric motor with bearings/brushes /pump impeller can cause pressures to vary as well as the feed voltage and the ground supply ... with a new fuel filter and you get 50 psi I would replace the pump..this is not horse shoes game .close does not help you . intake manifold leaking can ALSO be an issue here. the fuel pressure must first be corrected. this is not at the spec. |
so key on engine off fuel pressure should be 60 psi. with the engine idling should be above 53psi. pull the vac line off the regulator fuel should rise to 60 psi area. I use the purolator fuel filters now. same as ac delco in quality , much lower price. you will need a small cup to capture the leaking fuel when you do this . park so front end is higher than the rear. replacing the fuel relay with over 100,ooo miles is a good idea. even if the pump is the cause as a bad relay can damage a new pump motor. obviously replacing the fuel filter is needed anyway with the miles on it and with a new pump. dropping the tank is one way to do this pump or as others have found removal/slide back about 2ft, of the truck bed with 3 guys . rust in the filter is from not your tank , but that of the fuel supplier ! alcohol also GROWS crap in it ... |
about 3 months ago I looked at my records for the vehicles and realized it was almost 4o,ooomiles on the fuel filter.
I bought filters for the fleet of vehicles and replaced them all..now I find they all start with only one revolution of the start crank cycle. about 1.5 sec. before it was taking about 2 revolutions to get the engine to start... |
My money on intake, i have never had a driveability prob with over 50psi. I cant count how many times I have done these and no comebacks so far.
You need to do some more diag though before you go out and drop $250 on an intake.
