Go Back   Automotive Forums Car Chat > Mazda > Millenia/Xedos 9
Old 09-29-2009, 10:04 AM
jsproles jsproles is offline
Unhappy 1995 Millenia - Issues with running
Good day all,
I'm having a serious issue with my 1995 Milly.....she started up just fine this morning and I drove about 10 miles when she started to sputter......pulled into a gas station and she died.......now she won't start at all - nothing but crank over. Sounds like it wants to start, but nothing.
I noticed the check engine and the 'TCS off' lights are on. I've searched a couple other forums, but decided to post on here - and from what I can tell it sounds like it could be a vacuum leak and maybe some faulty sensors.
Going to check the usual things later today - fuel delivery, spark, etc. and will post my findings.
Any input would be greatly appreciated.
J
Old 10-16-2009, 07:07 PM
jhouston9 jhouston9 is offline
Re: 1995 Millenia - Issues with running
hey I have the same problem when it comes to the sputtering. I was informed that it was my throttle position sensor. This sensor causes the car to sputter when you press the gas or sometimes just drive (it depends on how bad it is). you can also be having vacuum problems in your radiator hoses or something cause my hoses goes bad all the time with this vehicle.
Old 06-18-2010, 08:06 PM
big white bufflo big white bufflo is offline
have you checked the fuel pressure regulator
Old 10-17-2010, 11:14 PM
jasper0618 jasper0618 is offline
have you read some of the old post on this car check 4 a vacuum hose leak .. you wouldnt happen to know what the trany bolt pattern is do you im looking to drop my 99 2.3 millenia s in to something lighter to drag with
