Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-20-2011, 03:16 PM
aem1988 aem1988 is offline
1999 Chevy Malibu starts up, dies, then starts fine
Hey everyone, I have a 1999 chevy malibu that about a year ago started having trouble starting up. I'll turn the key and the engine will turn over but then die back down. I'll turn the key a second time and the engine starts and runs just fine. What could be the problem here?
Old 05-20-2011, 03:33 PM
inafogg inafogg is offline
Re: 1999 Chevy Malibu starts up, dies, then starts fine
you can check fuel pressure to see if its at proper pressure
install gauge when cold,turn key on engine off to check pressure
you can also prime the pump a few times & see if it starts easier if
a gauge is'nt available.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 05-23-2011, 12:51 PM
rkvons's Avatar
rkvons rkvons is offline
You may have leaky injectors. Do like inafogg says and put a fuel pressure guage on the fuel rail and turn the key to on, but don't start the engine. Then turn it off and see if the pressure remains for 10 minutes or so. If not, fuel is either leaking back into the tank or leaking into the engine. Leaking into the engine will cause those symptoms.
Old 06-10-2011, 03:06 PM
jpar1983 jpar1983 is offline
Is this a serious issue? As in worth getting fixed?I'm having identical symptoms on my '98. Just changed the fuel filter, some seriously nasty stuff coming out of the inlet side of that when I took it off so that may have been a contributor. Is it more likely fuel injectors? I know I wouldn't dream of servicing those but don't know how much that usually costs. It helps to give it a little gas when starting. It may also help to turn the key to "on" for a few seconds before starting the car, I assume that gets the fuel pump going and restores pressure to the system. I say "may help" because I've only really had one or two chances to test this since yesterday.
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 01:08 PM
1999 Chevy Prizm - lock rod clip? n1ckml007 Prism 1 12-21-2010 09:41 AM
1999 Chevy Prizm - defogger switch light bulb ( LED replacement) n1ckml007 Prism 0 11-09-2010 09:26 PM
94 regal starts then dies?? xNGxCRASH Regal 4 02-21-2010 09:16 PM
It Starts, then Dies, then starts again...(Engine) cmyst Maintenance 0 08-23-2006 10:47 PM
Tags
1999 , chevy , malibu , problem , starting
