Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 09-18-2010, 02:21 PM   #1
Tampa 735il
No ground to battery
I have continuity to the positive post of the battery to the under hood jumper post. I do not have return continuity to the ground post of the battery. Car has been out of servise for three years and started. Next day nothing no dash lamps etc. Seems like the battry ground is lifted any hints?
Tampa 735il is offline   Reply With Quote
Old 09-18-2010, 06:30 PM   #2
91 bird
Cool Re: No ground to battery
could try running a wire from the neg terminal to the body and see if you get anything. if you do, then i would get a new ground cable. also check to make sure the cables are tight at each end, and battery is fully charged.
91 bird is offline   Reply With Quote
