Old 05-30-2003, 02:04 AM
lilHatCh lilHatCh is offline
Wink Calling all EXperts. I need a favor.<-----@
Iam trying to put a B-18a1 into a 88 honda civic hatchback & i dontknow which axels to put in the car,it seems the ones that came with the motor from a 92 Acura Integra didt fit. Any help you can offer Id really be thankful:frog:
Old 05-30-2003, 02:13 AM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
why would they not fit? Do you have the right tranny? Youve either got the wrong axles or tranny
blah
Old 05-30-2003, 02:26 AM
They fit on the tranny, but on the other side where they mount on the wheels they didt fit. I took back the axels thinking I got the wrongs ones & same thing happened. Do you know what kind of axels I should use or try again?
Old 05-30-2003, 02:33 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
not really sure about the axels only i know they are integra axels
im not sure if there is a diff in axles between like a gsr and a regular integra
a little of the subject but where in phoenix you at?
sorry i couldnt be much help
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 05-30-2003, 02:41 AM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
do the splines not fit in the hub because they are too big or what?
also on the teg axles, to make them fit you gotta take off the dust shield on the inside part of the knuckle where the axle goes through and then a small rubber ring around the axle near the boot where it goes into the hub...ill try to find an illistration
When I started reading about the evils of alcohol, I quit reading .
Old 05-30-2003, 02:46 AM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
The thing with 88 hatches is that in order to get the axels to fit you would have to either
1) switch out the outer cv axels or
2) get the front control arm setup off of the teg...
The reason for this is that on a 88 civic the spline count on the stock axel is 21 and on most others it is 25...
Hope that helps
This is the real melt pizzle
Old 05-30-2003, 10:12 AM
redmanjd redmanjd is offline
you have dust caps on the back of you spindles you have to remove and yo also need 91 axles
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-30-2003, 11:59 AM
do i need 91 honda axels or integra, Thanks for all the info this really helps me
Old 05-30-2003, 12:14 PM
CRXtc CRXtc is offline
Banned
Hope that helps
not control arm, steering knuckle
Old 05-30-2003, 01:19 PM
you need 89 to 91 teg axles
95 b18b
Old 05-30-2003, 01:33 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
90-91. 89 is 1st gen.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 05-30-2003, 03:14 PM
isnt 89 sill the b18a?
95 b18b
Old 05-30-2003, 03:19 PM
89 is a d16a1. 86-89 has 1.6L DOHC engine that resembles the JDM DOHC ZC but only makes 112-118hp.
90-93 has B18A1, 90 & 91 are OBD0, while 92-93 are OBD1. in 92-93, they also introduced the GSR model, which had a 1.7L "B17A1" DOHC VTEC engine, which is basically a B16 with a couple more ft/lb of torque.
Old 05-30-2003, 03:24 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
What model is your hatchie??
Old 05-30-2003, 04:19 PM
a 88 honda civic hatch ,there is no model for this year
