My firneds Forester won't start and alarm going off
Hi all,
I have a friend who called me and asked for my help. He has a 2001 Subaru Forester. My friend disconnected the battery to repair something with the spark plug. After reconnecting the battery, he says that the alarm is going sounding and the car won't start. I'm guessing there is an imobilizer. He told me that the keyfob says part number 88035ac231 Has anyone seen anything like this with their Foresters? Thanks
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD 98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors, |
Re: My firneds Forester won't start and alarm going off
I know I'm late to respond, but had they tried disconnecting and reconnecting the battery again to see if it made any changes? Did they ever figure it out? Let us know!
Like a boy - but BETTER! 2005 Subaru Forester 2.5X 1997 Honda Civic EX Coupe Inform yourself: AF User Guidelines |
When the Forester battery cables are disconnected, it clears the memory of the cars computer, when reconnected, the computer alarm will go off, Look for a small push button switch just to the left side of steering wheel, and just under the lower dash.. turn your car on to the assoc. position, or start it, then push the little bottom under dash to reset the alarm.
The complete system, gas regulation, etc. also needs to be reset after battery has been disconnected.. Start car and with foot on bake, and emergency brake set, put car in N then into Drive and let the car warm up sitting there, once showing the needle to have moved to start warming up, turn on air conditioner to let the computer reset RPM for the air conditioner.. That's it.. the computer should have reset all values of sensors and operations. Note.. If anyone has changed their own timing belt w/ gear pulleys & tentioner, also needs to know this procedure for resetting the computer before car will run correctly. Hope this helps... |
