Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 08-15-2010, 10:18 AM
EDDIE138301 EDDIE138301 is offline
A/C drain on a 1999 silhouette
Anybody know where the a/c drain is on the 99? I have the water leaking on the driver's side. I have cleaned the outside vent drains a while back. Does not leak now when it rains. I think the a/c drain is clogged, but I need to know where the darn thing is. Thanks for any info.
Old 08-25-2010, 07:32 AM
Milo2001 Milo2001 is offline
Re: A/C drain on a 1999 silhouette
On my 2001 silo, it is very hard to see. I had to take off the pass front tire and at the firewall for a half inch orifice sticking out. In relation to the engine it is inline with the alternator about 18 inches down.
I had water leaking into the cabin and fixed it with a rubber elbow and some vacuum hose glued inside the one end. A PCV filter elbow for a Chrysler, pt.# 47028 at AutoZone fit perfectly on the orifice. I glued the vacuum hose to one end and then glued the elbow and vacuum together and then to the orifice with weather strip adhesive. It's been working great for about 4 months now.
http://shop.advanceautoparts.com/wcs...8_pri_larg.jpg
Good luck.
