Go Back   Automotive Forums Car Chat > Buick > LeSabre
Old 08-09-2010, 11:51 AM
pbtenorio pbtenorio is offline
Radiator Cooling Fans
I have a problem with the maxi fuse (40A under the hood) for the radiator cooling fans blowing. The fans work fine until I turn on the A/C and then the fuse blows.
I installed two new relays (one for each fan) thinking that might be the cause. This did not fix the problem.
What else might I try?
One other clue is that the tempature light does not come on when the system overheats. The TEMP light does come on during the usual testing of the lights/indicators when you first start the engine.
Old 08-09-2010, 11:54 AM
maxwedge maxwedge is offline
A990 racer
Re: Radiator Cooling Fans
Disconnect one fan ( if 2) at a time see if the fuse blows. BTW always post the year.
Old 08-09-2010, 12:30 PM
Thanks I will give that a try.
