Old 07-25-2010, 04:01 PM   #1
PAINTER78
Trans/clutch issue, what you think?
I got a 81 Vanagon Diesel with a manual 4 speed trans. Its really hard to get into gear sometimes. Mainly after a long trip(200 miles plus). Sometimes when I go in reverse I hear a clunking nose(from around the trans). What do you think it is?
Thomas
PAINTER78 is offline   Reply With Quote
Old 07-25-2010, 08:59 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: Trans/clutch issue, what you think?
Not sure how this would have an effect on going in to gear, but the clunk could easily be a dry u-joint.
Have you changed the manual transmission fluid recently? If not, do so. Also, are there any noises associated with trying to shift in to gear when the transmission is hot?
-Rod
Old 07-26-2010, 09:41 AM   #3
PAINTER78
I added transmission fuild 1 year ago, it was a pint low. Only after a long trip(4 hours plus) it makes a clunking sound when in reverse and its hard to go into any gear sometimes. Do transmissions go bad at 135,000 miles? I would think having a 48 HP engine would be easy on it.
Thomas
Old 07-26-2010, 01:11 PM   #4
Blt2Lst
Blt2Lst's Avatar
If it is hard going into gear, you might have clutch issues.
When was the last time the clutch was replaced?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Blt2Lst is offline   Reply With Quote
Old 07-26-2010, 06:55 PM   #5
PAINTER78
I believe every major conponent on my van is orginal, never rebuilt/replaced. Vans at 135,000 miles. Its have trouble going into gears after 5 minutes of driving now. I turned off the engine and tried going into all the gears, it goes in just fine with the engine not running.
Old 07-26-2010, 08:43 PM   #6
Blt2Lst
Blt2Lst's Avatar
Sounds like a clutch problem..
Did you check the fluid in the slave if it has one ?
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 07-26-2010, 09:00 PM   #7
PAINTER78
No manual specifies a slave resivour, the master brake resivour is full.
Old 07-27-2010, 08:53 AM   #8
jdmccright
The RustBuster
jdmccright's Avatar
Clutch is shot.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Tags
problem , transmission
