Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-29-2001, 10:12 PM   #1
fuzzynaval
fuzzynaval's Avatar
What Octane do you use for P11?
I searched all through the forums...all I could come up with is what octane for a p10.
I have been hearing mixed answers. Few friends who work at a car shop told me 89-91 for gas. I have a friend who says...87 is all you need...anything more is just a waste.
So what do you guys use? and have you seen a difference in the octane for your cars.
fuzzynaval is offline   Reply With Quote
Old 10-29-2001, 11:35 PM   #2
jprimera
if you have set your timing at 17+ use 92 oct,here is a link with very good information about gasoline.
http://www.landsfield.com-faqs/autos...ine-faq/part1/
hope this help.
1998 PRIMERA GX 10.1 CR Chile.
jprimera is offline   Reply With Quote
Old 10-29-2001, 11:53 PM   #3
fuzzynaval
fuzzynaval's Avatar
link is broken...and haven't done anything to the car....still brand new...still stock.
Old 10-30-2001, 04:07 AM   #4
DCastillo
DCastillo's Avatar
Send a message via AIM to DCastillo
in chile, the octane is as high as 97
-The P11e Project
Carbon Metallic P11
Cosmetically Modified
DCastillo is offline   Reply With Quote
Old 10-30-2001, 04:15 AM   #5
primera man
"P-Man"
primera man's Avatar
Use either 91 or 96 here in NZ
View All My Models Here.
primera man is offline   Reply With Quote
Old 10-30-2001, 11:17 AM   #6
howard_w13
howard_w13's Avatar
Re: What Octane do you use for P11?
The only time a higher octane will make any difference is when you make major modifications (Ex:adjust timing, cams, turbo, etc.) to your engine. If your engine is stock, the only difference you'll is in your wallet.
howard_w13 is offline   Reply With Quote
Old 10-30-2001, 11:19 AM   #7
Nismoboy1
Nismoboy1's Avatar
Send a message via AIM to Nismoboy1
all your octane questions answered:
CLICK HERE
i'd just stick with 87
John H.
2001 Infiniti G20t - Aspen White Pearl
For Sale: 18" Gold Axis Se7en's and Eibach Pro-kits also for a G20 P11. Check the Infiniti G20 Classifieds Here
***My G20 - Click Here***
Nismoboy1 is offline   Reply With Quote
Old 10-30-2001, 01:02 PM   #8
jprimera
DCastillo owr oct 97 is the same usa 92 ,by the way the ipf 97 is actualy 98,6 oc ,just for the record.
Old 10-30-2001, 01:05 PM   #9
kris
Off playing with fire.
kris's Avatar
Just make your own high octane fuel
I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on your engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
kris is offline   Reply With Quote
Old 10-30-2001, 02:53 PM   #10
DCastillo
DCastillo's Avatar
we have a mad scientist on our hands!
-The P11e Project
Carbon Metallic P11
Old 10-30-2001, 03:00 PM   #11
howard_w13
howard_w13's Avatar
Speaking of octane, any of you guys use those octane boosters? I'm just curious to know how(or if)it works.
Old 10-30-2001, 03:08 PM   #12
DCastillo
DCastillo's Avatar
its doubtful
-The P11e Project
Carbon Metallic P11
Old 10-30-2001, 06:05 PM   #13
jprimera
This octane boosters works weel in a heavy modified n/a motors or turbo
Old 10-30-2001, 06:18 PM   #14
DCastillo
DCastillo's Avatar
ditto
-The P11e Project
Carbon Metallic P11
Old 10-30-2001, 06:36 PM   #15
fuzzynaval
fuzzynaval's Avatar
Re: Re: What Octane do you use for P11?
well I got 40 more miles out of a tank with 89 compared to 87/ 89-91 is about the same. so does that mean I shouldn't go below 89?
