Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-29-2003, 03:37 PM   #1
smokeydriver
Send a message via AIM to smokeydriver
corners
Okay, so I'm trying to figure this out, but don't know that much about cars. The corner lights on my 97' SE Max look "dirty". They aren't at white a color as my headlights. First off, is this the covers, or the bulb? If it's just the bulb, what's a normal, cheap bulb i can get that'll do the trick?
smokeydriver is offline   Reply With Quote
Old 04-29-2003, 03:55 PM   #2
DiS
DiS's Avatar
Send a message via AIM to DiS
Thats the stock bulbs Im guessing you have in there. Stock bulbs wont be as bright as the headlight. Nothing is wrong with your cover either. If you want your corner lights to be as bright as your headlights here is what you have to do. You have to take out the bulb from the corner light and turn it on 180 degrees. (doesnt matter clockwise or counter closewise ) on both sides of the bulb there are two small metal pieces (they are very little) you have to take one of them off ( i think the one that sits a little higher than another one) you can do it with any pliers. Then turn bulb 180 degrees around and put it into the corner light. TA DAAA!!! You are done. Sit back and relax and watch your bulb get twice as bright as it was before. Hope this helps.
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
DiS is offline   Reply With Quote
Old 04-29-2003, 06:25 PM   #3
97wvmax
Send a message via AIM to 97wvmax
i jus rewired mine
97wvmax is offline   Reply With Quote
Old 04-29-2003, 07:25 PM   #4
DiS
DiS's Avatar
Originally posted by 97wvmax
i jus rewired mine
Rewired corner lights? or blinkers with sidemarkers? or all together?
Auto Trans
Old 04-30-2003, 12:22 AM   #5
97wvmax
jus the corners. i had the blinkers rewired but got tired of them so i put them back to normal.
Old 04-30-2003, 02:32 AM   #6
DiS
DiS's Avatar
Kewl.
Auto Trans
Old 05-11-2003, 04:50 PM   #7
EPVQ30
EPVQ30's Avatar
i gotta do this mod soon.. i hate my dim corners and bright sidemarkers they look odd. however, i tried taking out the housing and it was a PITA, now i got some WD40 and waiting on bulbs to try it again.
SHIFT_99 SE-L 3 pedals
EPVQ30 is offline   Reply With Quote
