Old 05-11-2003, 04:39 AM   #1
killah_xft
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
the mysterious squeek
alright I have been on this caper for the past few days, and I am still baffled by it. yesterday I planned to attack the squeek with a can of silicone spray, and WD-40, but to my suprise it did'nt show itself when I turned my car on... so I decided, well maybe it'll come back later, and I put the 2 cans of lube in the trunk to use later when it appeared again.. and just when I got to work, and stepped out of my car the small squeek was back. I popped the hood, and looked for the elusive squeek, only unable to locate it... I checked the timing belt, the Ac drivebelt, and the alternators drive belt, but all sounded normal, it was coming from the other side of the engine, but I can see no moving parts on that side of the engine, at least none that are exposed, or not covered up by a cover. can somone help me pinpoint this annoying bugger? it's not noticeable from inside the vehicle, but you do notice it when you are outside standing next to it, while idling..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
killah_xft is offline   Reply With Quote
Old 05-11-2003, 10:16 PM   #2
hondaman-iac
hondaman-iac's Avatar
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
do you have an aftermarket intake on it ?
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
hondaman-iac is offline   Reply With Quote
Old 05-12-2003, 01:07 AM   #3
killah_xft
nothing in the engine bonnet has been modified... Just did an oil change, and new air filter in the oem airbox..
