Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 03-25-2009, 01:37 PM   #1
larryhydro
99 e150 stillhesitating and stalling at acceleration
so far i've changed mass air flow sensor,crank position sensor, fuel filter, wires, plugs, ignition coil, and van continues to hesitate and buck during acceleration. in the morning it stalls completely when it's put into drive. after driving for half hour or so it runs perfect. any ideas?
larryhydro is offline   Reply With Quote
Old 03-25-2009, 06:46 PM   #2
rhandwor
Re: 99 e150 stillhesitating and stalling at acceleration
I would ohm the temperature sensor if your scanner won't read this for you.
http://fordfuelinjection.com/?p=28 The link will give some readings.
rhandwor is offline   Reply With Quote
Old 03-25-2009, 09:53 PM   #3
G0ldRush
G0ldRush's Avatar
I agree with that because if the temp sensor is faulty it will run the engine too rich and stall (too much gas )
If they don't have it, I don't need It!
G0ldRush is offline   Reply With Quote
Old 07-25-2010, 12:37 PM   #4
vcamilleri
My van is doing the same. I was told after a code read it is most likely the egr solenoid.
vcamilleri is offline   Reply With Quote
Old 07-25-2010, 02:13 PM   #5
rhandwor
Normally an EGR valve will cause stalling when the engine is warm not when it is cold.
