Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 06-26-2010, 01:30 AM   #1
Xxvicman
hesitation/light throttle 50+mph
hi, im experiencing hesitation at light throttle between 50-55mph and sometimes at 45 and ive done the following:
replaced spark plugs and coils with motorcraft
replaced fuel filter
cleaned MAF sensor
took it to a trans expert and he said its not the transmission also got a trans filter and fluid replacement
got a catalytic converter restriction test and it was good
i have a P0420 catalytic efficiency code below threshold bank 2 but its been there way before i started having this problem
any advise? thx in advanced!
1999 crown victroria 135,xxx
Xxvicman is offline   Reply With Quote
Old 06-26-2010, 11:00 AM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: hesitation/light throttle 50+mph
Check EGR valve and DPFE sensor. DPFE sensor is located on the very back of the passenger side head. It has an electrical connector and two rubber hoses attached to it. Often water from the exhaust condenses in this and can give false readings. Removing the sensor and smacking it in your hand to get the water out usually helps.
Check the EGR for proper operation by removing the vacuum line from the top of the EGR valve and using the vacuum line from the fuel pressure regulator to apply vacuum to the EGR valve. If the engine gets rough and then compensates for the roughness, it is working. When removing the vacuum, the engine should return to higher RPMs and then compensate to normal once again.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
