Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-10-2010, 11:52 PM   #1
rmwilson
automatic locks and driver side window not working
My driver side window all of a sudden stopped going down ( literally overnight) I thought it was the master switch console on the driver door panel- i bought a second one and exact same problem ... the automatic locks and the driver side window does not work at .. the other three windows all work no problem with the master switch on the drivers side door..
both the locks and the driver side window just stopped working all of a sudden .....? not like the window was getting slower over time...
I have checked all the fuses .. nothing is blown ...
Any ideas?
Ryan
rmwilson is offline   Reply With Quote
Old 06-11-2010, 09:41 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: automatic locks and driver side window not working
Any ideas?
Ryan
YEAR MAKE AND MODLE?
Check power and ground out of master switch to window motor and lock solenoid.
MT
Old 06-11-2010, 11:55 PM   #3
rmwilson
its a 2000 gmc envoy ( jimmy with the envoy package) - is the lock selonoid located in the door
thanks
Ryan
Old 06-12-2010, 09:44 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Yes
One in each door.
And may be operated by relays.
MT
Old 06-22-2010, 11:58 PM   #5
rmwilson
It has to be before the doors I'd think as both the driver and passenger automatic lock switches are not working -unless the ground in one door completes the circuit to the other door.
I'll have to open up the door panel and find out ...
Ryan
Old 06-23-2010, 09:04 AM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Some times you can check it by pulling window and lock switches out of door panel.
A good repair maqnual with a good wiring diagram would help on testing and repair.
Good Luck and let us know how it goes.
MT
Tags
automatic , broken , driver , locks , window
