Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-09-2010, 07:02 PM   #1
kevin160
idle learn process?
ok so for the past few days my 1994 cutlass supreme 3.1 has been running terrible. I replaced plugs and wires and cleaned out the IAC and TPS sensors. The car surges/hesitates until it eventually stalls out. then u have to wait an hour or so to restart the car. it also takes me 5-6 trys to get it started after it sits over night. there is no check engine light.
now i was thinking the FPR, fuel filter, or fuel pump. but after doing some research on the net i learned about the idle learn process when your battery dies.
A few months back me and my buddy installed subs and an amp into my car. my friend stripped my positive battery terminal so maybe 4-5 days out of the week my battery cable would disconnect but all i hav to do is tap it and it would make the connection.
so im thinking im gonna get a new battery so i can make sure its always connected, because i read that your car will relearn its idle process after driving it for a while. but is there a way i can know for sure this is the problem? the battery probably disconnected 30-40 times on its own since i had the stereo system. thanks.
kevin160 is offline   Reply With Quote
Old 06-09-2010, 07:37 PM   #2
maxwedge
A990 racer
Re: idle learn process?
The idle learn will not prevent starts, check the fuel pressure.
Old 06-09-2010, 08:12 PM   #3
kevin160
k thank you very much. time to get a fuel pressure test kit hoping they are under 50 bucks.
Old 06-10-2010, 08:59 PM   #4
kevin160
where is the fuel test port on the 3.1? just trying to find everything before i get my tester.
Old 06-11-2010, 08:50 AM   #5
maxwedge
A990 racer
On the fuel rail on top of the engine.
