Go Back   Automotive Forums Car Chat > Buick > LeSabre
Old 06-14-2010, 02:10 PM
SRC1968 SRC1968 is offline
99 limited lesabre trany slippen
Hi all. I have had 2 friends (not mech.) test drive my Lesabre and both say its the trany. what type of tranys can i use to replace the one in the car now... do i have to have another 99 lesabre trany? or are there other options... and how do i know what to get...
any advice would be greatful... 1st time here and using this forum...
thx
Old 06-14-2010, 07:38 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 limited lesabre trany slippen
Welcome to AF, call any reputable salvage yard they have interchange books that will tell you what transmissions are direct fits.
Old 06-15-2010, 05:35 PM
happydog500 happydog500 is offline
When the trans is slippin, you will get a Check Engine Light, with a code. If not, it could be something else. "Trans Slipping" on these transmissions could be a valve body. Common problem with these trans.
Do you have a CEL, or a Code? Which one?
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 06-16-2010, 12:05 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
You need a trans specific scanner to monitor trans function. Take it to a transmission specialists!
Knowledge can be communicated, but not wisdom!
Old 06-17-2010, 09:03 AM
Jrs3800 Jrs3800 is offline
agreed... This could be as simple as a PCS issue... The car needs to be scanned...
Old 06-22-2010, 06:45 AM
polarzak polarzak is offline
Check plugs and wires first.
