Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 06-26-2011, 12:51 PM
Maxamilious Maxamilious is offline
Intermittent high idle
2001 GP 3.1L
So.. what would cause my car to idle high, intermittently? Usually around 1500-2000 rpm. Shutting it down, and starting it up again often gets rid of this. Mid-drive it will also sometimes kick into a high idle, and randomly go back down. No SES light.
Old 06-27-2011, 11:10 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Intermittent high idle
There are several items that can cause this issue. 1. Bad vacuum line. 2. Sticking throttle position sensor. 3. Leaking intake manifold gasket. 4. Bad or sticking idle air control motor.
Old 06-27-2011, 08:58 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Try disconnecting the harness to the MAF(with engine off) and start the engine. See if the problem goes away, you can drive like that for a while, it will trip the CEL.
If it does try cleaning the MAF with CRC MAF cleaner available at autoparts stores.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-30-2011, 06:58 PM
Thanks all! Swapped out the TPS and IAC and all seems well so far.
Old 06-30-2011, 08:12 PM
olopezm's Avatar
Thanks for letting the forum know what fixed your problem. I'm glad you figured it out!
Oscar.
'92 XFi: intermittent high idle + high temp SchlockRod Metro 5 01-16-2009 09:24 AM
Intermittent high idle rabrew1953 Regal 6 08-09-2008 08:31 AM
intermittent high idle backerm Ranger | Courier 8 02-12-2008 06:17 PM
2000 Venture Intermittent High Idle Speed EAGLESFAN Venture 12 07-09-2007 02:15 AM
intermittent high idle '93 Acura Chrisbio Integra 2 10-02-2003 05:03 AM
