Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-20-2010, 02:36 PM
crackedvenom crackedvenom is offline
How to drain tranny fluid?
I want to drain and replace my tranny fluid. first time doing it and im not sure where the part is to take off so it can drain. im pretty sure its on the right though. can anyone explain, or have a picture they can show me? that would be great.
thanks a lot
Old 05-20-2010, 02:44 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: How to drain tranny fluid?
You don't specify year or engine, but most Camrys have a 10MM allen head bolt on the bottom of the transmission pan to drain the fluid.
Mike
Old 05-20-2010, 04:57 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
If you want to replace all the fluid, you will have to flush it. Draining the pan only drains about a third of the fluid. There is a substantial amount in the torque converter and the valve body. (this is assuming you have an automatic transmission). You may have to drain and fill the differential also.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
