'99 Dakota 4x engagement problem
When I hit the 4x High button it shifts into 4 high with no problems. When I hit 4 low the light flashes back and forth from high low and the transfer case makes loud nasty noises
![]() Any help would be greatly appreciated! |
Re: '99 Dakota 4x engagement problem
Shifting between 2hi and 4hi basically just locks the front driveshaft in at the same ratio as the rear. when shifting between 4hi and 4lo, it is actually engaging another gearset to reduce the gear ratio in the transfercase. Loud grinding indicates shift fork is not fully engaging, or gear damage, which could take out remaining parts andnleave you stranded. Best bet is to get transfer case to knowledgeable mechanic for teardown and inspection, unless you are mechanically inclined. Nothing magical inside, just gears and bearings....
