Go Back   Automotive Forums .com Car Chat > Buick > LeSabre
Old 04-14-2010, 09:52 PM   #1
plumcrazy89
93 Lesabre electrical??
A bolt dropped into lighter socket,and now my cars fan won't kick on,the tranny doesn't shift right and a few other things are wrong.I replaced the ECM and that did not fix can anyone HELP me figure out what else it could be?????
plumcrazy89 is offline   Reply With Quote
Old 04-14-2010, 10:25 PM   #2
spinne1
Re: 93 Lesabre electrical??
Did you check every fuse in all three places?
spinne1 is offline   Reply With Quote
Old 04-15-2010, 12:16 AM   #3
plumcrazy89
Yes i checked all fuses all good??
Old 04-15-2010, 09:26 AM   #4
Mickey#1
Does the lighter work? If not then you probably missed a blown fuse.
Mickey#1 is offline   Reply With Quote
Old 04-15-2010, 01:35 PM   #5
plumcrazy89
Yes lighter still works and i have checked every fuse.I am lost at what to check next??
Old 04-15-2010, 01:39 PM   #6
plumcrazy89
Does anyone know if it could possibly be the ignition switch causing these problems?
Old 04-15-2010, 08:28 PM   #7
Mickey#1
Which fan isn't working, HVAC or radiator? What else isn't working? More info will help locate the problem.
Old 04-15-2010, 08:52 PM   #8
plumcrazy89
The rad fan and the tranny has a slow take off.That seems to be it.I thought there was more.
Old 04-15-2010, 10:49 PM   #9
Mickey#1
You might have a problem with the VSS (vehicle speed sensor). If the computer thinks the car is moving above a certain speed then it'll turn the fans off because enough air is already flowing through the radiator. I'm guessing the tranny won't downshift if the computer thinks the car is moving too fast. Does the speedometer work?
Old 04-15-2010, 10:56 PM   #10
spinne1
The cigarette lighter has power all the time from Fuse 11 in the main fuse box under the dash on the left of the driver seat.
The radiator fans get power from Fuse 16 in the main fuse box, and also Fuse 4 in the under hood fuse area. They power goes through a high speed coolant fan relay, and a low speed coolant fan relay. It also goes through two coolant fan resistors on its way to the right hand coolant fan motor.
The low speed coolant fan relay is the one all the way to the right of your eight relays under the underhood fuses.
The high speed coolant fan relay is the relay second to the right.
The easiest way to test these I think is to swap in known good relays (from further to the left for example.) To get the relays out, push a flat-head screwdriver under the relays but above the metal piece below the relay about 1/2 to 3/4 of an inch in and push down (there is a tab that has to move out of the way in order for the relays to slide forward and out.) If these check out okay, try jumping power to your fans and see if they operate.
Old 04-15-2010, 11:16 PM   #11
plumcrazy89
As for the speed sensor thing,the fans don't start when key is on,or at driving around,the tranny acts like it slipps,and tranny was fine before bolt fell in lighter socket.
Old 04-16-2010, 11:10 AM   #12
Mickey#1
You didn't mention if the speedo works. I think they were electronic (not cable driven) in 93.
Old 04-16-2010, 08:51 PM   #13
plumcrazy89
Yes speedo works ,only problem is tranny and fan.
Old 04-16-2010, 10:31 PM   #14
plumcrazy89
Tried the relay thing and it all did nothing!!!I'm lost???
Old 04-16-2010, 10:44 PM   #15
serge_saati
serge_saati's Avatar
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Originally Posted by plumcrazy89 View Post
As for the speed sensor thing, the fans don't start when key is on, or at driving around, the tranny acts like it slipps, and tranny was fine before bolt fell in lighter socket.
I think it's the weirdest problem I ever seen in automotive history.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
serge_saati is offline   Reply With Quote
