Old 12-25-2009, 11:27 AM   #1
teegolf
97 Lumina 3.1 EGR Valve Testing
Continue to get a EGR low flow code on the car. I have removed the EGR to making sure it is clean and the plunger moves freely. Checked for clogging and debiris in ports and all appears OK. Is there a way to test the EGR valve itself by connecting it to 12 volts on a bench? Which wires at the plug supply currnet to the EGR and what activates them? Appreciate any help to test before I go buy a new EGR.
teegolf is offline   Reply With Quote
Old 12-25-2009, 12:03 PM   #2
kenrap
Re: 97 Lumina 3.1 EGR Valve Testing
Give the following pdf a read, it should help.
http://www.wellsmfgcorp.com/pdf/Counterpoint3_4.pdf
Cheers!
kenrap is offline   Reply With Quote
Old 12-25-2009, 08:39 PM   #3
teegolf
Great article but I need information on how to test a single solenoid EGR and not a triple unit.
Old 03-18-2010, 06:29 PM   #4
tb496bb
Originally Posted by teegolf View Post
continue to get a egr low flow code on the car. I have removed the egr to making sure it is clean and the plunger moves freely. Checke9p0401)d for clogging and debiris in ports and all appears ok. Is there a way to test the egr valve itself by connecting it to 12 volts on a bench? Which wires at the plug supply currnet to the egr and what activates them? Appreciate any help to test before i go buy a new egr.
i have a 99 lumina with 3100 v6. Im hsving the same code with my car . Everything i read say to check the manifold port for blockage. I ran my car with egr removed and found good exhaust flow on one port and good vacuum on the other but im still going to try cleaning out the intake port for egr valve
tb496bb is offline   Reply With Quote
Old 03-18-2010, 07:55 PM   #5
bsr2002
Check this out!
http://www.youtube.com/watch?v=hpB6CELWYhQ
I did this with my 98 Lumina. There was gunk in mine as well. I only wish there were more help vids like this.
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
Old 03-18-2010, 08:57 PM   #6
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
egr tube (leading off the exhaust manifold) may be clogged
and i have cleaned that egr passage (like in the video) and yes that thing will clog totally up
kevinb70 is offline   Reply With Quote
