Old 02-06-2010, 10:48 PM   #1
birminghamwildcat
Exclamation Starting problem-ready to pull my hair out
97 Rodeo V6 with 5speed manual bought used from freind. Knew there was a starter problem before I bought it but $600 plus a starter well it was a steal. Or so I thought. Ran fine across the county home after we popped the clutch until I got about two miles away from the house and then the motor started lugging on acceleration. I figured it was because it was because the battery was dead from sitting up so long. Charged the battery, replaced the starter, and still wont even click when I turn the key. The positive cable connection to the battery is slightly loose but it was not loose enough to register over 12 volts on the gage. Only things in the cockpit working when the key is turned on is the gages and lights on the dash. No radio, no heat/air, no interior or headlights/taillights. Any ideas?
***************Update 1 2/8/09*****************
New terminal connections. Still not starting with starter. One clutch pop to move to avoid towing and noticed the tach registered zero. Batt meter registered zero after startup but before registered over twelve. I'm thinking it may be the ECU?
birminghamwildcat is offline   Reply With Quote
Old 02-07-2010, 05:51 AM   #2
99 Fronty
Re: Starting problem-ready to pull my hair out
Must be rock-solid tight and clean. The starter needs Volts AND Amps. You have one but not the other.
'99
99 Holden Frontera SE (Isuzu Rodeo) 3.2 V6 DOHC
Victoria, Australia.
99 Fronty is offline   Reply With Quote
Old 02-07-2010, 03:09 PM   #3
amigo-2k
Isuzu Guy
Pull the battery and the alt and have them load tested...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 02-08-2010, 12:16 AM   #4
Cat Fuzz
The starter pulls the most power of anything in the vehicle. You can have all sorts of things with enough power to work but not enough power to operate the starter. Check all connections and make sure they are tight and clean. Check your clutch safety switch as well. As a test you can also directly energize the starter by simply using a piece of wire and touch to the big terminal on the starter and the small terminal. That will energize the starter directly. It will also by-pass any safety features that are present so make certain that the truck is out of gear and parking brake engaged.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
