Turned crankshaft while timing belt was off HELP
I have a 97 Probe 2.0 that I was replacing the timing belt on. Like an idiot I turned the crankshaft when the belt was off. How can I fix my error? I do not remember how far I turned it or if I went a full revolution?
Re: Turned crankshaft while timing belt was off HELP
if the belt was off then you only moved the crank cam any thing else should
have stayed in place.realign crank check when belts back in place before cranking you should be ok asuming you lined it up before you started btw how did crank get turned by hand or did it get cranked by key?? dont no if engine is/is'nt a free spinner(does'nt/does bend valves) good luck
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
I turned it by hand (ratchet) wasn't thinking. I was trying to show friend how it turns the rotor, think I did full revolution to get the rotor back around but really can't remember.
should be fine line crank up recheck with belt on
good luck
#5 | ||
Look at the diagram you were using maybe an oil pump has to be lined up also.After your done rotate by hand and recheck the marks. |
