Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-14-2009, 04:15 AM   #1
katstevens
85 300zx turbo starting/warm up problem
Hello,
This problem has been ongoing for a long time and I can't figure it out. When I start the car it's fine but after about a minute the idle drops very low, almost to the point of dying and starts running really rich. If I hit the accelerator to get the rpms up, it bogs and stutters. But then, as soon as it reaches operating temp, all that stops and it runs fine. I have replaced the cold start sensor and the crank position sensor. I also ran the diags on the computer and came up with nothing. Any ideas? Your help would be much appreciated!
katstevens is offline   Reply With Quote
Old 11-24-2009, 05:37 PM   #2
toddrs93
toddrs93's Avatar
Re: 85 300zx turbo starting/warm up problem
Did you ever figure this out?
Throttle position sensor maybe?
Interested to here the fix.
toddrs93 is offline   Reply With Quote
Old 12-09-2009, 02:15 PM   #3
perna00
perna00's Avatar
Send a message via AIM to perna00
I got the same exact problem. If I use the a/c; it will idle higher and keep it running a little better. It is something with the amount of air entering the system. Maybe the air bypass valve or the auxilary air?
perna00 is offline   Reply With Quote
