Old 03-13-2005, 11:59 AM   #1
Bassman808
1998 Blazer Oil Pressure Gauge
Just bought a 1998 Blazer LS w/83K on it.After warm up & on the highway,what is the normal reading the oil pressure gauge should be at?
Thanx!
Bassman808 is offline   Reply With Quote
Old 03-13-2005, 02:40 PM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: 1998 Blazer Oil Pressure Gauge
What speed?
BlazerLT is offline   Reply With Quote
Old 03-13-2005, 03:40 PM   #3
Bassman808
At 55 mph.
When it's at idle it's around 40~42
Old 03-13-2005, 03:59 PM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
between 1/2 and 3/4
Old 03-13-2005, 04:12 PM   #5
cubanlorenzo
Send a message via AIM to cubanlorenzo
my 95 while driving at any speed, as long as im on the gas, it will be a notch above the middle(40) when stopped and idle, goes below half. 1/3 id say. that too low?
cubanlorenzo is offline   Reply With Quote
Old 03-13-2005, 04:44 PM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Re: 1998 Blazer Oil Pressure Gauge
Yip, completely normal.
Old 03-13-2005, 04:47 PM   #7
blazee
Problem?
blazee's Avatar
The norm would be about 30 - 40 at idle and 45 - 60 while driving.
Personally, I wouldn't run it this low, but the minimum while hot is:
1000 rpm..............6 psi
2000 rpm............18 psi
3000 rpm............24 psi
blazee is offline   Reply With Quote
Old 10-13-2009, 04:28 PM   #8
eamz
I have a 98 blazer. I was driving at about 85 wen my check engine soon light came on. There is no oil leak. The temperature stays normal. But i have no idea why the light came on.
eamz is offline   Reply With Quote
Old 10-14-2009, 12:46 PM   #9
jdmccright
The RustBuster
jdmccright's Avatar
Any other symptoms other than the check engine light? I presume you have low to no oil pressure if you're posting to this old thread. Check your oil level. If the stick is dry, you're burning oil. Then get a scanner and read the trouble code.
The other common problem is a loose gas cap. Check the o-ring for good seal.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
