04 avalanche 5.3 running lean on bank 1
![]() Join Date: Mar 2005
Re: 04 avalanche 5.3 running lean on bank 1
does it have any misfire codes also? what manifold seals...intake or exhaust? pull the spark plugs on bank 1. how do they look? is one of then kinda white looking, or all 4? post back what you find!
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
No there isn't any missfire codes, Intake manifold, the truck idles nice so I don't think there's a fowl plug, I'll pull them and check, The O2 code is gone now, just the running lean on bank one,
what was the exact code for the 02 sensor? it might be a plug that has bad gap setting, could be an injector clogged/faulty. the possibilities are high right now, and trying to narrow it down. a white spark plug end would mean lean on that cylinder, if on all 4, would mean something wrong on that side of fuel rail....either all 4 injectors bad at same time(doubtful and you would have other driveability concerns it would seem), or a clog in the rail on that side, or some sort of electrical problem over there. awaiting more info about the plugs. just for record, how does the truck run, any performance issues, or just the light?
I don't remember the o2 code, I have not had time to check the plugs yet, and it runs great, idles good, a few hours ago I switched the o2 sensors to see if the running lean on bank 1 would switch sides to eliminate the o2 sensors, then I,m to check the plugs, I doudt it would be a plug because then I think it would be running rich in the exhaust ? , but could be.
I just hate that light thank you, your comments are very helpful |
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Fuel pressure or MAF sensor or vacuum leak can give lean running codes.
MT
#7 | |
My truck was setting lean codes on both banks. After a few days of research and multiple resets, I decided to open the hood and take a look. The air intake tube between the air filter housing and the engine was disconnected. I reconected it and reset the codes. The code never came back. I know it sound like BS, but it really was causing the lean codes.
2008 Honda Civic EXL - Daily Driver 2000 Silverado 1500 LT - Boat and Haul 2005 Honda Pilot EXL - Wife and Kids 1997 Ford Mustang Cobra Convt. - W/E |
#8 | |
check fuel injector o-rings for leaks on bank 1,while running,spray brake clean around injectors or check for vacuum leak somewhere else if engine rpm changes,you most likely found your leak
#9 | |
A990 racer
![]() Join Date: Mar 2002
Good info, but please check the dates before posting, this is over 1 and 1/2 years old and inactive, thanks.
