Go Back   Automotive Forums .com Car Chat > Honda > Del Sol
Old 01-24-2009, 01:26 PM   #1
twinly01
Question won't run please help!!
My brother in laws del sol starts, runs for like 1 second then just dies. Replaced fuel filter, got results! it started and ran for half an hour. then he shut it off, started the car again and it wouldnt run for more then 1 second again. its like it keeps stalling, and no matter how much you push on the gas pedal it doesn't rev at all it just dies. any ideas??
twinly01 is offline   Reply With Quote
Old 02-07-2009, 05:32 AM   #2
L E D
Re: won't run please help!!
main relay behinde the fuse box....opcorn:
L E D is offline   Reply With Quote
Old 09-19-2009, 10:58 PM   #3
bacchus_gc
i changed the main relay (2 times) and the problem still there ... Runs for 1 second only.... If i try and try the car start ... Each time that i try delay less time to start until starts quick like no problem ... But the next day the same .. Any ideas???
bacchus_gc is offline   Reply With Quote
Old 09-19-2009, 11:00 PM   #4
bacchus_gc
the problem is the fuel pump ... Doesnt work because doesnt recive electricity....
Old 02-06-2011, 12:23 PM   #5
FrodoGT
FrodoGT's Avatar
could be the fuel pump on its way out. The main relay tends to be an on/off situation like a light switch, and usually when the car is hot/ambient temperature. How many miles are on the car? It may be worth looking into a new fuel pump as a maintenance item anyway. I think your going to find a ton of garbage in the tank and a dying pump.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
FrodoGT is offline   Reply With Quote
