Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 08-24-2009, 06:41 PM   #1
sccars49
'86 E150 5.0, no power to fuel pumps
I have checked the fuel pump relay & also impact shut off solenoid & both are ok. However, no power to pumps. Pumps do work when hot wired. The engine turns over with starter ok. What else do I need to check? Any specific fuse? Thankyou in advance for any help.
sccars49 is offline   Reply With Quote
Old 08-24-2009, 10:59 PM   #2
driver540
Re: '86 E150 5.0, no power to fuel pumps
Check for power at the fuse terminal and relay. If you have power there, then you may have a break in the wire or a bad ground
driver540 is offline   Reply With Quote
Old 08-31-2009, 07:23 PM   #3
sccars49
thanks for the response. we did find that it was a bad ground connection. We grounded it & then started working. Thanks again.
Old 08-31-2009, 11:06 PM   #4
driver540
Your welcome. Glad you found it.
