Old 09-28-2009, 08:10 AM   #1
Kiyosh1
Kiyosh1's Avatar
Daihatsu Copen Euro Tec
Hey Guys..
Well..I'll be makin a replica of my girls car..i did 1 before and she put it on the dash board..and she parked in the hot sun which lead to melting one side of it....Here's some pics of the previous model i made..
The Damage:
As u can see, the right side of the car caved in..the windscreen kind of coiled up..but it aint in the pic..the dashboard caved in as well..
The Actual Car:
The Replacement:
The Rims: from the previous kit..the rims are stock
The Process:
the front and rear bumper.. gonna cut the grills out..and replace with mesh..
Dry Fitting..every things seems well..
Thats all for today..comments welcome..
Kiyosh1 is offline   Reply With Quote
Old 09-28-2009, 11:12 AM   #2
MidMazar
MidMazar's Avatar
Re: Daihatsu Copen Euro Tec
The first one came out nice, i think what you need is a diecast so it doesn't melt.
In Progress
Old 09-28-2009, 12:20 PM   #3
buggy2356
First I love that car and think that it's very sweet that you make one for your girl. Hope that she will appreciate your work and take good care of it in the future
The first model looked very well made and i'd like to see the WIP on the 2nd. Will definitely follow your progress!
buggy2356 is offline   Reply With Quote
Old 09-28-2009, 03:51 PM   #4
Kiyosh1
Kiyosh1's Avatar
lol..i dont think they have copens in die cast..and i didnt think that the sun would be hot enough to actually melt it...
i hope so too..lol..the 1st one wasnt very well made because i missed a few small details..i guess this 1 will turn out better..
btw..anyone know of any site that has meters and deliver worldwide? or do i have to scratch build them..
Old 09-29-2009, 07:25 AM   #5
Kiyosh1
Kiyosh1's Avatar
hey guys..
a little update on the copen..went to the hobby store today to find out that they ran out of primer and flat black..since i was there, i thought of tryin out scratch building meters..
as u can see, the meters are stuck to the windscreen..well its her car..so i wont ask much..
it's my first time scratch building..so..dont expect much..
i'll be using:
-cutter
-putty to fill the styrene tubes..
-3.2mm styrene tube
-3.2mm flat styrene strip
first i'll cut out about 3mm length of tube to make the meter..and cut off the edge so that it'll aline with the windscreen..
then glue onto a 3mm long flat strip..
then fill the hole with putty..
and tada~..meters..lol..
and it'll look something like this
well..thats all i can do today with what i have..comments welcome..
Old 09-29-2009, 09:30 AM   #6
buggy2356
Nice scratch build )) How are you going to make sun screens for thous? As I cold see from the photography they are not strate... I think it wold be easier to shape the form from tube and then insert the gauge (to fill the hole). And if you take flat styrene strip for base and make it thiner it will look more realistic.
By the way if you have dremel or power drill, you can use it as lathe machine and with knife make shapes as you pleased. That what I do for that kind of jobs.
Hope it will help and wonderful that you decided to scratch build instead of buying!
Old 09-29-2009, 11:45 AM   #7
tuned.by.twenty
AF Vendor-TBT's Owner
tuned.by.twenty's Avatar
The gauges look good. It's a shame that the first model was ruined, but it looks like you've got the replacement coming along nicely.
tuned.by.twenty is offline   Reply With Quote
Old 09-29-2009, 01:57 PM   #8
MidMazar
MidMazar's Avatar
I would be terrified to have gauges in a convertible car. Looks like there must be no thieves in Singapore.
BTW nice job on the gauges, but i also agree with the above. Try using smaller flat styrene. Also i would cut the tube on an angle so you get the gauge lip like in the picture. Then sand out the inside with a file, then putty. Nice progress either way.
In Progress
Old 09-29-2009, 03:43 PM   #9
Kiyosh1
Kiyosh1's Avatar
i was thinkin of usin straws to make the visors for the meters..but that'll be a later part..needa see if i can get the decals for the meters 1st then i'll be able to adjust everything..
Old 09-29-2009, 03:44 PM   #10
Kiyosh1
Kiyosh1's Avatar
thank you..well..its too early to say..so far so good..but its just the beginning..lol
Old 09-29-2009, 04:07 PM   #11
Kiyosh1
Kiyosh1's Avatar
lol..its a hard top convertable..and singapores a small country..people cant run far..
Old 09-29-2009, 04:42 PM   #12
Kiyosh1
Kiyosh1's Avatar
i guess this is what u guys are tryin to tell me..
one down 2 to go..this is strainious man..
Old 09-29-2009, 06:12 PM   #13
kaho
kaho's Avatar
If a hobby store sells them, I think it would be easier to make the visor parts using aluminum tubes and use an electric drill as the tool. Just cutting that angled part of round styrene would give me a sore neck within 5 minutes, it's hard to make all 3 the same, and they all might not match up with the rest of their gauge bodies the same way.
Find a tube with the size that you can fit right over your plastic gauges. Angle one end using needle file (put file on a table and grind your tube end on it), cut if off by some length (more than what you need so you can put the piece into a drill). Put the piece into a drill. While spinning, thin angled edge from inside with round needle file/ or thin entire tube from outside with flat needle file, sand/polish off file marks with sandpaper, finally, saw off the tube length you want. Afterwards tuck your round plastic gauges into the aluminum tube, then the piece is ready for paint.
Similar to what buggy2356 is saying above but just going deeper into the subject. After trying the power drill lathe method I can't stop using it! It's fun and you can make the final product so thin it's hard to do the same with styrene due to the difference in strength. Exhaust tips made this way look excellent compare to styrene tips as well!
kaho is offline   Reply With Quote
Old 10-08-2009, 02:51 PM   #14
Kiyosh1
Kiyosh1's Avatar
hey guys..
sorry for the slow progress..have been realy busy lately..anyway..couldnt start on the interior cause the flocking material has yet to arrive..fixed on the wheels and primed the body..primed the body white cause i realised how many coats of yellow has to be sprayed on grey primer
Old 10-08-2009, 11:12 PM   #15
MidMazar
MidMazar's Avatar
Don't forget to do last bit of sanding of the front opened grills and bumper before you paint. Always stick with a white primer on lighter colors including red,white,yellow,and light greens and blues. Good luck.
BTW I don't know if you airbrush or not, but what i have been doing lately is : if the paint color is going to be lets say orange, i add a few drops of orange paint to white primer. And what you get is a light orange primed body, i use this method on Tamiya TS paints decant.
In Progress
