Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Talk
Old 06-08-2009, 09:53 PM
andy5.01984 andy5.01984 is offline
Angry 1994 Mustang GT 5.0 Only Runs at Idle Help Please
1994 Mustang GT 5.0 only runs at idle and wants to die when it reaches 1500 RPM. Help please.
Old 06-09-2009, 02:26 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Re: 1994 Mustang GT 5.0 Only Runs at Idle Help Please
my first thought is at the intake. check and make sure that all of the plumbing is sealed and tight, too much air being pulled in after idle RMPs confuses the computer. after that i would need more information, have you done anything to it lately? any reason for it to be running on six cylinders like the plug wires wrong? if it runs normally at idle, 98% of the time it is the computer if it is the information it is receiving or the processor itself we'd have to hear more to diagnose.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 07-23-2009, 03:43 AM
Interstate526's Avatar
Interstate526 Interstate526 is offline
sounds like it's not getting enough air, or not enough fuel. like BigDan said, a sensor could be throwing off the computer. maybe the MAF or something?
"All good things are wild and free"
-Henry David Thoreau
Old 08-02-2009, 10:51 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
Low fuel pressure, exhaust blockage, plugged up injectors, intake blockage, plugged fuel filter, or ignition related problem.
If you want to know if it's a sensor like MAF, just unplug it and see if it runs like normal. The computer will compensate for the missing signal with it's own limp home signal.
Old 08-03-2009, 02:44 AM
Davescort97 Davescort97 is offline
Escort guy
Pull the wire connector to the MAF. It will go to rich mixture by default. If it is starving for fuel try this to find out if it is. If it runs OK with the MAF disconnected start looking for vacuum leak.
