Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-15-2009, 07:00 PM   #1
boostjunkie333
boostjunkie333's Avatar
Send a message via AIM to boostjunkie333
Valve cover gasket Replace
Hey gys, im gonna be chanigng out the vc gasket this weekend bc there are traes of oil seeping from the one ont here, and also over a long period of time coolant seems to be disapeering, so im gonna change that and narrow down the listof what could be the problem...
Anyways, quick to the point, do i need to replace anything else while im in there? routine maintenance wise...like is there naything on eclipse engines that has a nack for wearing out that wouldnt be abad idea to replace? like the spark plug seals...ect.?
thanks!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
boostjunkie333 is offline   Reply With Quote
Old 05-15-2009, 07:47 PM   #2
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Re: Valve cover gasket Replace
Spark plug well seals should come with the gaskit. But yea you should replace them. Thats it for the VC job. Make sure to put sealent on the right parts of the gaskit. Also dont overtorque the VC bolts.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 05-16-2009, 12:51 PM   #3
Blackcrow64
Blackcrow64's Avatar
Replace the PCV valve while you've got it off too. It's only a couple bucks for a new one. And definitely be sure not to over torque the valve cover like Silver said. It would make for a bad day. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Blackcrow64 is offline   Reply With Quote
Old 05-16-2009, 09:54 PM   #4
boostjunkie333
Is that nec.? considering i did away with the pcv system as per install instructions for the portfueler and turbo kit...
bu thanks for everything else!
Old 05-18-2009, 12:17 AM   #5
Blackcrow64
You may have removed the system that properly vents it back into the intake and such, but it still needs to vent the crankcase pressure out... Mine just runs a line to my catch can. Where is yours running to now then?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
