Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-06-2009, 01:05 PM   #1
jcase350
Idle Problem
I need some direction. When I start my 90 camaro 350 TPI, it idles fine. When it gets warmed up it starts to idle up and down and dies unless I keep my foot on the gas. It showed a Code 32, EGR circuit. So I have removed the EGR valve and tested it, it appears to be good, it holds the vacuum. I cleaned it and put it back on, no more code, but it is still doing the same thing. I just replaced the distributor cap and rotor.All this started after swapping the transmission. What would be my next step? EGR Solenoid? Is there a way to test the solenoid? Thanks
1990 Iroc-z 350 TPI
jcase350 is offline   Reply With Quote
Old 02-07-2009, 08:16 PM   #2
jcase350
Re: Idle Problem
Latest Update...I tried a new MAP sensor, IAC valve, and new plug wires with no luck.
1990 Iroc-z 350 TPI
Old 02-08-2009, 01:05 AM   #3
Morley
Re: Idle Problem
Sounds like it might be a throttle position sensor (TPS). To test it use an analog ohm meter hooked to the sensor across pins A&B (disconnect the harness from the sensor). Now, watch the needle as you open and close the throttle. The needle should sweep across the scale in a smooth motion, no jumping around.
Morley is offline   Reply With Quote
Old 02-08-2009, 02:28 AM   #4
Genopsyde
The President
Genopsyde's Avatar
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Idle Problem
whatever it is, it's only happening in closed loop mode. I don't know if that helps narrow anything down though. IAC could be a possibility as well.
Have you run any fuel pressure tests?
Genopsyde is offline   Reply With Quote
Old 02-08-2009, 11:17 AM   #5
jcase350
Re: Idle Problem
The TPS and fuel will be my next check. Would a clogged fuel injector or filter cause the rough idle in closed loop? I also took the EGR solenoid off. It had a bunch of dirt caked on the coil so I cleaned what I could off, still no help. i also double checked all vacuum lines and found no leaks.
1990 Iroc-z 350 TPI
Old 02-08-2009, 12:11 PM   #6
Genopsyde
The President
Genopsyde's Avatar
Re: Idle Problem
i don't think your egr has anything to do with your idle problem. how does it sound when you rev the rpm's up? is it smooth, or rough and choppy?
Old 02-08-2009, 05:25 PM   #7
jcase350
Re: Idle Problem
It seems to run a little better at higher RPMs but you can still tell it wants to run rough. I have gotten a intermitten SES code 32 light. Do you think there is a underlying problem?
1990 Iroc-z 350 TPI
Old 02-09-2009, 03:57 AM   #8
Morley
Re: Idle Problem
Well, the EGR could be the problem IF it is stuck wide open. It would cause a bad idle at that point.
If it isn't open all the time, the code 32 means that the MAP sensor isn't seeing a drop in pressure when EGR is being requested. that is how the ECM knows the EGR valve opened. If this is the case, the ECM will alter the spark map and may cause a lack of power and possibly a slightly rough idle (especially if you need a tune up). If the valve checked good, then check all of the hoses going to it. Check that the solenoid is working, then it is down to a possibly bad MAP sensor.
Old 02-10-2009, 07:20 PM   #9
jcase350
Re: Idle Problem
Could the O2 sensor cause a rough idle?
1990 Iroc-z 350 TPI
Old 02-11-2009, 02:30 AM   #10
Genopsyde
The President
Genopsyde's Avatar
Re: Idle Problem
I would look at the map sensor like morley suggested first.
Old 02-11-2009, 01:23 PM   #11
jcase350
Re: Idle Problem
I installed a known good MAP sensor and it did the same thing. What else?
1990 Iroc-z 350 TPI
Old 02-12-2009, 03:42 PM   #12
Genopsyde
The President
Genopsyde's Avatar
Re: Idle Problem
yea, i think you have a misfire.
Old 02-12-2009, 06:29 PM   #13
Morley
Re: Idle Problem
what Geno said is a possibility. To check it start the car up when it is dark out and pop the hood. Look for any sparks down at the plug boots and at the distributor. Then check the wires themselves to be sure they aren't worn through somewhere.
Old 03-04-2009, 11:34 PM   #14
timz592
Re: Idle Problem
when you swaped your transmission out, did you remove the distributor to make the top 2 trans bolts easier to remove, also you said you replaced the cap and wires, did you make sure there all in the right order?
timz592 is offline   Reply With Quote
Old 03-05-2009, 01:42 AM   #15
Genopsyde
The President
Genopsyde's Avatar
Re: Idle Problem
i suggest removing the distributor when dropping the transmission.
