![]() Join Date: Apr 2009
dies after 10 minutes
i have a 1995 chevy blazer it runns high for about 10 to 15 minutes starts running realy rough and dies i think somthing is heating up the brain so last time it did it i changed the brain and it re started and run for a nother 10 - 15 minutes and died what could be killing the brain
#2 | ||
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Re: dies after 10 minutes
What engine and engine code and computer and dist setup? Flat top or old style dist cap? Computer on fender or inside cab? What brain did you change? New or used or rebuilt? Does it do it all of the time? Have you checked for lose of fuel pressure or los of spark when it does it?
#3 | ||
yes it does it all the time the fuel pressure does not go down i just put in new fuel pump and filter
AF - Advisor
#6 |
#7 | |
Could be losing compression after the engine warms up. Do a compression check on your cylinders and get back with the results. Did you already check for sure that u are loosing fire?
#8 |
#9 |
#10 | |
When you keep talking about brain are you talking about your ignition module or your ecm?
#11 |
#12 |
#13 |
#14 |
#15 | |
radiator over flow tank i have a disttibutor it is next to the coil i have one of my blazer and one of my new motor and when it died the first time i thought that might be it and tried that it did not work
