Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Register FAQ Social Groups
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-06-2008, 08:43 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
2 step with DSMlink
does anyone know how to set up the 2 step with DSMlink? i finally folded and bought the clutch switch i needed from Mitsubishi, and now im having trouble figuring out how to set up the launch control w/ the clutch... i can get it to work when the car is sitting still, but the only problem is, when i do not press the clutch, the launch control is still active. i know the the switches are functioning properly, because the cruse control still works. i guess what i am looking for is how to set up the shutter box? i would ask on dsmlink, but i feel like a noob asking, and here, you guys know, that is not the case. any info will help. thanks. opcorn:
Old 12-07-2008, 12:47 AM
steviek's Avatar
steviek steviek is offline
Re: 2 step with DSMlink
ecu- rpms then you click enable clutch cut.
then go to rpm's and set your desired launch rpm and you're disable mph and you're done!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 12-07-2008, 12:49 AM
steviek's Avatar
remember though your engine rpm will always be limited by your launch speed if you are under the speed you have designated so if you just sit while you're stopped and rev you will still hit the box limiter. It only shuts off after you past a certain mph. I use 7mph.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 12-07-2008, 01:04 PM
Black99GST's Avatar
so their isnt a way to make the shutterbox inactive when im not pressing the clutch? like it will rev normal when the clutch isnt pressed, but when i press the clutch, the shutter box is then active at say, 3500 rpm?
Old 12-11-2008, 12:34 PM
steviek's Avatar
no not with link. why would you want to just rev the engine like that anyways?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 12-11-2008, 02:38 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
So with link the studderbox runs off of speed and not the clutch switch? Blackgst said he bought the clutch switch he needed but whats the point of even hooking that up if you cant rev over your launch rpms till your over the set MPH?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-11-2008, 07:24 PM
steviek's Avatar
It looks only at the speed to engage the launch rpm limit, so you'll need to provide some sort of speed signal to the ECU, even if it isn't accurate.
|NLTS is for clutch switch mostly
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 12-11-2008, 08:13 PM
Holset powered 420a
Ok I got you. That makes sense now.
98 Eclipse GS Turbo
2001 BMW 325i - DD
