![]() Join Date: Apr 2005
94 SE stalling need help
1994 Bonneville SE 3.8L (non-supercharged) 112000mi
First off, I'll start by saying I don't believe this is a mechanical problem. I believe it is electrical. I have searched a few threads and come up with possible TPS problems or EGR problems, but I wanted to put my issue out there and see how the responses compare to what I found. These are the symptoms: When driving or sitting, occasionally the vehicle chime will rapidly ring 3 times and the speedometer will jump approximately 25-30MPH and return to the actual speed I am traveling, also the tach will jump approximately 2000-3000 RPM. Sometimes if I am not on the throttle while driving the car will die causing me to come to a stop, put it in park, and restart the engine. The SES light will sometimes stay on from startup to the next time I turn the car off, and sometimes it doesn't come on at all. Today I replaced the spark plugs, cleaned the MAF, replaced the air filter, changed the trans fluid filter, and changed the oil. While driving the car runs relatively strong, and still gets fairly decent mileage. My best guess would be TPS or VSS. Any input is appreciated. Thanks in advance. |
#2 | ||
AF Moderator Elite
![]() Join Date: Feb 2005
Re: 94 SE stalling need help
Knowledge can be communicated, but not wisdom! ![]() ![]() |
#3 | ||
There is a possibility that the PCM may be going belly up on you..
stupidity should hurt
![]() Join Date: Aug 2004
I agree with HotZ28, that the battery cables and engine ground straps need to be checked (since you replaced the other parts he mentioned). It could also be a corroded underhood fuse/relay center or PCM.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
have you scanned for codes??
#7 | |
i don't know how to scan for codes on this car I am confused by the write ups also.
