Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 09-14-2008, 05:30 PM
mdhbhouse mdhbhouse is offline
87 accord - makes 'buzz' sound when slowing down
My son's 87 accord just started to make an 'rrrrrr' or 'zzzzz' sound when you take the foot off the gas and the card starts to slow down.
I mean it starts fine, goes into gear ok etc. and is fine as long as you are accelerating but as soon as you go to slow down it sounds like some gear is coming in contact with another gear that is spinning.
It wouldn't be the starter would it somehow?
Hard to diagnose I imagine based on my description but any guesses?
Old 09-15-2008, 06:38 PM
Re: 87 accord - makes 'buzz' sound when slowing down
ok. Doesn't seem to be the starter as I swapped it out and same problem.
Now I'm starting to think something to due with the transmission?
When I step on the brake and the car starts to slow down it gets very loud.
As you can see my automotive troubleshooting skills are limited so I think I'll have to take it to a mechanic and at see what they say.
Old 09-16-2008, 02:35 PM
ok. So I misdiagnosed my problem and it is a transmission problem.
So no need to respond to this thread.
Old 09-16-2008, 04:04 PM
inafogg inafogg is offline
sorry no one replied back i would of guessed exhaust but atleast you figured it out hope it was an inexspensive fix.
Old 09-16-2008, 10:11 PM
No fix yet! I'm just deliberating over what can or should be done now.
The mechanic gave me an estimate of $500 to $700 to swap out the transmission (he hadn't actually sourced one yet) but sounds about right as I found one at a wrecker for $250 plus $400 to do the swap.
That's probably more than the car is worth so I'm just wondering if it is something I could tackle.
Hard to answer that I know not knowing my 'DIY skills'.
I've replaced starters, alternators, done brakes and had a friend help me rebuild my old Mazda 626's engine after it blew the head gasket a few years ago but never a big job like this. My thoughts were I'd try and find out how much work is involved (if I need special tools etc.) and then decide from there.
Old 09-16-2008, 11:15 PM
im assusing its an auto dont believe you said.the hardest part is the weight unless you can get a trans jack!! its really not to hard on your back with/without the jack figure a full day with a floor jack.if it is a manual trans then its even easier & no jack needed.Good Luck with what ever you decide!!
Old 09-17-2008, 02:48 PM
Thanks inafogg. Last question, and it is an auto (2.0L carb engine).
Do you have any 'info' on what I need look for?
I found this on a DIY site but I'd like to find some Honda info if possible.
"The 1986 Honda Accord used a model F4 automatic transmission. The only other Honda that used the model F4 automatic transmission is the 1985, 1986 and 1987 Honda Prelude with Fuel Injection. The carburetored Honda Preludes for those years used a model AS automatic transmission."
Old 09-17-2008, 04:05 PM
hello, im not sure of your question??''what i need to look for'' are you talking about what tools or what other cars that have the same trans,or a DIY guide
most junk yards can tell you what other cars used same trans,manuals are available online.i have a 90 - 93 accord manual.sorry not sure what your asking.Mike
btw how sure are we that its the trans?? what did they say was wrong with the old one??
Old 09-17-2008, 09:36 PM
Sorry 'bout that. Mostly just wondering about what other cars have same trans but if a junk yard can tell me then that answers that.
As far as what exactly is wrong with the tranny the mechanic didn't really say as I think it was just a case of cheaper to swap in a working one that try and diagnose an fix the one I have.
I did phone a transmission place and he just told me to take it to Honda...
I guess I could try and replace the fluid and 'filter?' or something?
Again, I've posted on a few sites and nobody has really provided any feedback on what to do or try (maybe based on the age/value of this car).
Maybe I'll just do some searching for transmission fluid changing etc.
Old 09-18-2008, 05:09 PM
is it possible to video it.not so much to see but rather to hear what its doing??changing fluid/filter is pretty simple but without hearing cant say it would/would'nt help & with oil prices going up about $40 DIY repair. Mike
btw its odd the trans shop would'nt want the work!!
Old 09-19-2008, 09:34 AM
I could video it to capture the sound. Then what would I do with it?
I agree it is a little odd. They were the ones that were able to fix up my old Chrysler minivan by replacing solenoid etc.I think. Maybe their thing is just domestic's or they figured I wouldn't spend big bucks on a repair so why waste their time. I dunnoh.
Old 09-19-2008, 01:51 PM
well as far as video you'd have to be able to down load to your computer after that just post it on this site
is there any thing wrong with the car(trans wise)other than the noise??
my thinking is, if thats the only thing & car drives ok maybe just leave it alone & wait n see.if it does get worse & its the trans O well your going to replace it anyways & if it doesnt get worse you just save time & $$ just M.O. Mike
btw if its not the trans it may give you more symtums of what it maybe
Old 09-19-2008, 03:22 PM
I guess I really didn't describe the situation very well in this port did I?
To recap:
The car starts fine and normally goes into gear with no problems although the last time I took it out (it didn't go into R initially and then after going into D3 and back to R it kinded of slammed into gear).
While driving I can accelerate no problem but when I take my foot off the gas and start to slow down is when I start to hear the 'buzzing or ZZZZzzzzz sound' (hard to describe) and then I can't accelerate anymore and I have to apply the brakes to slow down before I can step on the gas again. On my way home from the garage it seemed like if I drove slow enough say 20mph it worked ok.
So it really isn't working ok now.
I do appreciate the feedback and I didn't realize you could post a video clip on this site. I know how to get it on my computer etc. so I'll look into doing that if you are still interested.
Mark
Old 09-19-2008, 03:51 PM
yes mark hearing the noise may be a help.when you cant accell.when driving does the engine rev up or bogg down or what??Mike
Old 09-20-2008, 02:30 PM
OK. So I have a video just not sure how I upload now unless I just post it somewhere else and provide you with the url?
Engine seems to act normally. I step on the gas it revs up just the tranny doesn't respond except for the "slippage?".
