Old 03-02-2003, 02:09 PM   #1
xlosinghopex
Send a message via AIM to xlosinghopex
Is an MSD ignition worth it?
I have bosch +4 Platinum spark plugs and the bosch premium wire set already and was looking into some MSD ignition parts. I was considering the Sport Compact Ignition, Blaster coil, and distributer but need more info. What can I expect from this? Will it just smooth out my throttle response or actually increase HP? I don't have forced induction or anything so I don't use any more fuel, I figure that makes a difference.
xlosinghopex is offline   Reply With Quote
Old 03-02-2003, 04:35 PM   #2
jcrx
Send a message via AIM to jcrx
Without a lot of mods or boost teh stock ignition system is more than adequate.Honda has one of the best OEM systems on the market.By the way Hondas don't like Bosch products,stick with NGK you will get better results,but no you won't see anyimprovement in you performance with a MSD,you may even start getting interference in your system.
jcrx is offline   Reply With Quote
Old 03-02-2003, 05:33 PM   #3
xlosinghopex
Thanks for the info, you saved me time and money. I'm curious to where you heard that Bosch products don't perform well on Hondas. My spark plugs and wires perform great and I'd never heard of anyone else complaining.
Old 03-02-2003, 05:54 PM   #4
Milliardo
Milliardo's Avatar
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
My bestfriend also used Bosch spark plugs on his Civic, and he didn't have any problems either. In fact, he was happy about it because his car performed very well.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Milliardo is offline   Reply With Quote
Old 03-02-2003, 06:04 PM   #5
jcrx
They do work,but my experiance with them is they foul quicker and are not as "in tune" with the needs of the ignition system,if that makes sense.I have used them both and have always gotten a smoother idle and overall performance from the NGK's.
Old 03-02-2003, 06:28 PM   #6
xlosinghopex
I also remember reading somewhere that Honda had a notoriously weak coil. I don't remember where I read this so I don't know how reliable it is. Any info on this? Also before I even read this my coil had gone bad.
Old 03-02-2003, 06:32 PM   #7
jcrx
I actually switch to a aftermarket coil in my old rex and had a bunch of problems with interference.I have never had a problem with the stock coils,especially in any newer models.But I have heard mention of this somewhere too.
Old 03-07-2003, 07:32 PM   #8
Frostbyte
Send a message via ICQ to Frostbyte
Did you have your wire coming from the coil to the distrubuter running over the Intake? How close was your intake to the distrubuter? Because I had a buddy (Mayhem Member) that had the same problem until he pop'ed his hood at night and found that his distubuter was sparking on his Intake and that was causing the issue.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Frostbyte is offline   Reply With Quote
Old 03-07-2003, 08:03 PM   #9
maxspeedhonda
maxspeedhonda's Avatar
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Actually they are not known to have weak coils. JCRX is absoulutley right in saying that Honda systems are more than good enough for most applications. Leave it alone unless you are planning n2o or FI where you need more fuel. What is true though is that they often tend to prematurely have problems. I have read many articles about it. I'm sure you already know this though.
maxspeedhonda is offline   Reply With Quote
Old 03-07-2003, 08:40 PM   #10
jcrx
No,it was the 1st gen with the in line capacitor and it was pushing more power than it liked.
Old 03-07-2003, 11:19 PM   #11
Frostbyte
Oh ok.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
MPG of 93 Dakota 5.2 Magnum w/MSD Ignition tripod12133 Dakota 0 07-27-2010 11:21 PM
Ignition Upgrades? Worth it? CBFryman Non Specific 9 02-18-2006 09:25 PM
Follow up. MSD, is it worth it? dakejh Engineering/Technical 0 06-30-2003 10:53 AM
MSD ignition worth while? perndog1 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 11-06-2002 10:33 AM
msd ignition vs stock ignition cas8_1999 Engine 16 01-05-2002 04:31 PM
