Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-14-2008, 11:53 PM
PeeWee1949 PeeWee1949 is offline
pinging
I have a 1999 Ford Ranger. Shortly after starting, it will start pinging. It gets pretty loud. It will then start missing, lose power and die. It won't start again until it cools down, and then does the same thing shortly after restarting.
Old 06-15-2008, 11:52 AM
Davescort97 Davescort97 is offline
Escort guy
Re: pinging
Welcome to Automotive Forums. I don't thing the problem is a preigniton ping such as will happen on the highway on a load with too low octane of fuel. I suspect mechanical problems. It could have dropped a valve seat into the combusion chamber and it could be hitting a piston. I suggest taking the plugs out check for a bent ground electrode. Something is causing a problem in a cylinder. It would be a good idea to run a compression check.
