Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-10-2008, 08:17 PM   #1
sub-1
99 Sub. A/C Problems
I have a 1999 Suburban with front and rear A/C. When the A/C is on and I put the fan on med or high, I hear a suction sound and the air stops blowing thru the dash vents. I have to shut the A/C off and turn it back on to blow thru the vents. It doesn't do it on low.
The rear A/C is not affected......
Any ideas?????
Thanks
Peter
sub-1 is offline   Reply With Quote
Old 06-11-2008, 05:41 PM   #2
grumpy5
Re: 99 Sub. A/C Problems
Sounds like a bad controller. If you check through the past threads on this subject, you will be able to verify. I have seen similar problems posted here before.
grumpy5 is offline   Reply With Quote
