Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 05-22-2008, 02:04 PM   #1
glc77
Exclamation 1997 bravada key stuck
Just completed an upper end rebuild, had the battery charging and hooked her up but no power, the key is in the run position, tried cleaning terminals, unplugged and plugged it in again and nothing. Before the rebuild it was running. Any thoughts
P.S. the key is stuck in the ignition.
glc77 is offline   Reply With Quote
Old 05-23-2008, 08:19 AM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 1997 bravada key stuck
Sorry, gotta ask....
Is the battery ground cable connected good to the engine block?
Chris Stewart is offline   Reply With Quote
Old 05-23-2008, 05:35 PM   #3
glc77
We never removed the ground from the engine block. Installed new battery, found that the other was bad. Have power at the starter. Could there be a factory alarm disconnect? We have no lights anywhere.
Old 05-23-2008, 09:45 PM   #4
ericn1300
AF Premium User
ericn1300's Avatar
you might have a passkey or passlock igntion system. some info here on bypassing them: http://www.the12volt.com/installbay/...917~PN~1~TPN~1
ericn1300 is offline   Reply With Quote
