died, won't start
Hi all,
My 1994 wt 1500 V6 about 75k mi was running perfectly. Yesterday I was using it and when I went to start it it started, then stumbled and died. tried a few times it stumbled a few and would not start at all. I tried poring some gas down the injector and it started. I'm thinking fuel pump, any place I should look before I have to drop the tank. Thanks |
Re: died, won't start
Good question, will check when I get home.
Thanks |
The pump is electric. Therefore, anything that disrupts proper operation of the electric motor--corroded connections, broken wires, etc.--will cause problems.
The actual pump part can fail, too, as can the in-tank plumbing. You've already checked to see if the fuel filter is plugged...right? Next step is to verify fuel pressure, and if it's low, to verify that the pump is getting proper voltage and proper ground. Keep in mind that there's a wire harness INSIDE the fuel tank, and they're a common corrosion point. Some fuel pumps even come with a replacement in-tank harness, it's so common. This harness was purchased for my Lumina, but it's similar if not identical to the one in my '88 K1500. The replacement harness is a longer, "universal fit" item.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
