Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 04-08-2008, 01:16 PM
SnipesXxX SnipesXxX is offline
Drain and fill
Do I put the 50/50 stuff back in or full dex cool? This is a 2000 GA SE with 2.4L Dex Cool. I want to put Dex Cool back in it.
Old 04-08-2008, 05:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Drain and fill
The final mix should be 50/50 (or whatever you need for freeze protection). If you just drained and filled, add 50/50 to it. If you flushed the block with water, add 1/2 the capacity of straight coolant, then top it off with water.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-09-2008, 12:27 AM
Re: Drain and fill
k Thx
BTW does anyone know right off how many gallons the 2000 GA SE needs with a Quad 4?
Old 04-09-2008, 06:26 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: Drain and fill
If it was entirely empty it takes about 3 gallons total. Fill it with the appropriate mix and bleed the system. The quad motors can take a while to bleed, mine used to take me about 45 minutes for the tstat to open and close several times and it will swallow a bit more coolant during the process.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
