| Non Specific This is the forum to post and generalized racing questions. |
380HP Isn't Enough...
Spring time Mods!
Seams dead... Thought I would see what people are planing on doing to their cars this spring/summer.
Maxima I've got 2 things I am planning on. I'm rebuilding my front end. New Control arms, bushings, ball joints, tie rod ends... Needed to replace all the bushings so why not everything. I'm considering doing the wheel barings, but dont have any signs of problems. I'll pull them out and look at them, maby regrease them if need be. The second thing is replacing the fuel filter, got the 300ZX fuel filter for the maxima. Datsun Needs a brake overhaul. I have to take everything apart to see where I'm at and what I need. I have a leak somewhere in my rear brake lines, only my front brakes work. Other then that, if I have any extra money I'll be sure to try to put it into the maxima, or buy a macbook pro. I have a feeling i am in the need of a new CAT. If thats the case, I would want a full 3" out and bla bla bla,money money money...Car sounds great. Mid April, Poly and I are doing a lot of fun stuff to his cars. Taking about 4 days and going to Utah.
WHAT KEEP IT STOCK! Well that takes the fun out of it. [center]
AF Vendor
Re: Spring time Mods!
Finish the turboback, trying out one last new BPV, Cobb Accessport and springs, and some general goodies (silicone boost tubes, paint the intercooler cover, NGK 1 step colder, shifter bushings), start prepping for law school. Also, if I find myself a surprising sum of money, get the stock K04 ported/polished with a new wheel.
2006 Redline Red Nissan 350Z Base K&N|Falken I am just that JDM tight, yo.
May not be spring...but more so summer mod plans
Im planning on getting GM stage 2 kit and an ingalls torque damper. Later on hopefully a 2.9 inch pulley and a cobra heat exchanger
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
![]() Join Date: Dec 2006
First I plan on getting the thing back on the road(vacuum pump bearings disintegrated and are in the oil pan thankfully they didnt get into the oil pan). After I get a better paying job i hope to save up for a manual tranny or a Sportline suspension kit from AMG.
1987 Mercedes Benz 190D turbodiesel -5 speed transmission swap |
nothing planned for the car, all my money's going into the ninja. new front(-1) and rear sprocket(+2), new chain, new tail light w/integrated blinkers, and a jardine slip on exhaust. should run me about $1000.
BP's Rides; - 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's. - 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims. ![]() ![]() ![]()
just trying to get the mean green working.
![]() Don't act like you don't love it.
503/2000 |
#7 | |
The Red Baron
<Thinks about it, brain implodes........>
![]() Anyhow, needless to say, a shit load. I have an entire room of parts that need to go on and more will be on the way before the end of modding season. Well, here's a list of crap for both cars. GTC:
I'm also debating between doing the transmission work or the body work this summer. I'm sure there's something in that damn room I'm forgetting. Stealth:
I'm thinking about doing the brakes as well with new rotors and SS flex lines. I also want to powder coat the calipers but I don't know what color. The new wheels will be black with a polished lip so I'm thinking black, white, or red. Not sure.... |
#8 | |
![]() Join Date: Apr 2005
Fix Bumper and add pipe to make a true CAI
Oil change RP Catback Exhaust- thinking Magnaflow, possibly others but 89% sure Tires- 265 back, 245 front, most probably GForce KDW's Gears if I have enough time and money- 3.73 or 4.10's |
#9 | |
srs biznis
Hrm...spring time mods...lemme think...
BUY A NEW FRIGGIN CAR!! (maybe) |
#10 | |
Buy a new car. And assuming another rod does not go flying through my motor and breaking out of the bottom on my bike agian, I will not have to do anything mechanical to it. However, I did just buy some new leathers, hand grips, factory effex seat cover and a few other misc. things.
#11 | |
On Fire!
Ehh... who knows with me... I flip flop so much on what I want.
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#12 | ||
srs biznis
#13 | |
On Fire!
At least I have good taste...
#14 | ||
You should consider yourself lucky that the rod didnt continue its path and exit through your leg, taking god knows what with it. Plans = Buy Mazdaspeed 3 in June. CAI, CDFP, SB-E will follow almost immediately after I get it. Not much after that, atleast until i build up some bank to get the FMIC or boost controller.
MOAR BOOST ![]() Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi |
#15 | |
currently its:
fix rust on drivers door fix rust on trunk fix rust starting in passenger door install header and midpipe replace rear o2 sensor get the front bumper repainted get the rear bumper repainted get the right side of the car repainted mount the cd deck in a different location after all that, hopefully sell the sentra, as im looking for a 94-95 clean miata clean of rust and paint damage, with the Limited slip.
2008 Mazda 6 ATX 2.3 Liters of Slowness For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car. |
