Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 08-26-2005, 12:38 AM
JSherry58 JSherry58 is offline
Programming remote (FOB) for 2004 Toyota Solara
I tried to program a new remote for my 2004 Solara using the closest instructions I could find.. 2000-2003 Camary.. it seemed to be going well, all of the things that were supposed to happen ("doors locks will automatically cycle 3 times"...etc) except the final step... door locks should cycle... nothing happened... not only was I unable to set my new remote, but my existing one no longer works... Any help would be greatly appreciated.. John
Old 08-26-2005, 09:35 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Wrong forum buddy
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-26-2005, 10:13 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Programming remote (FOB) for 2004 Toyota Solara
Originally Posted by BlazerBoyLT98
Wrong forum buddy
I need say nothing except BLazerLT move him to his correct rice paddy
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 08-26-2005, 10:32 AM
Re: Re: Programming remote (FOB) for 2004 Toyota Solara
LMFAO!
K&N Air Filter
Old 08-26-2005, 10:37 AM
I thought there was a place on this board where this was to be put i wanted to put the link up for him but i cant find it.
Old 08-26-2005, 10:39 AM
http://www.geocities.com/toyota_speed2003/
or
http://www.automotiveforums.com/vbulletin/t172063.html
that one there seems popular
Sequoia 01 - 03
Camry 00 - 01
4Runner 99 - 04
Sienna 99 - 03
Solara 99 - 05
1. Start with the following conditions: you are seated in the vehicle
a. Key is out of the ignition.
b. Drivers door is open, all other doors are closed.
c. Drivers door is unlocked.
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. cycle the power locks 5 times, evenly spaced and relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. cycle the power door locks 5 times. (Same as before)
b. Turn the ignition to on, then back to off.
c. Turn the ignition to on, then back to off.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically) indicating successful entry into programming mode. Return to STEP 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate this vehicle, including any old transmitters.
7. Close the driver door.
From that thread on how to do it
Old 09-19-2008, 09:08 AM
upssnowman upssnowman is offline
I used this on my 2006 and it worked but not all of the sequence were quite the same no beep to notify that you were in program mode but it was and followed seperate remote seq, to add them
and step 7 the door should already be closed as per instructions
