Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Register FAQ Social Groups
Old 02-05-2008, 05:39 PM
Goosehunter Goosehunter is offline
1998 Engine keeps missing while cold
I have a 1998 S-10, 2.0L engine, 2 wheel drive, with 60,000 miles on it. I was having a problem with the engine missing when I first started up the truck in the morning. After the vehicle warmed up in about 5 minutes of driving the problem went away. I could leave the truck for 4 or 5 hours and it would be fine when I started it again later in the day. So pretty much only when it was left for 8 or more hours the problem would occur. So I replaced the wires and the problem went away. A month and ahalf later and the problem is happening again. I assume it has to be in some way electrical since it did go away the second I changed out the old wires but I don't see how it could be a problem with the wires since I just changed them.
Any ideas?
Old 02-06-2008, 09:11 AM
16th hippy 16th hippy is offline
Re: 1998 Engine keeps missing while cold
could be wires are fouling due to exhaust heat. is there a leak at the manifold? seen alot of cracked 2.2 manifolds from s-10's....mine included. could also be a fuel problem. could be a spark plug. start by getting fuel pressure readings and bleed down test and go from there.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
