1998 s10 not starting
i am puzzled! i have a 1998 s10 that will not start. i've replaced coil packs,ign. mod. and still not starting.it will crank over but will fire.i have spark and fuel. i know someone on here might be able to help me.
Re: 1998 s10 not starting
check fuel pressure
1995 Factory Blazer Service Manual for sale, PM if interested. |
fuel pressure ok,could this be a timing issue,or crank sensor maybe
I'm having the same issue on a 1998 s-10. New wires, cap, rotor, coil, plugs....what else could it be??????
@Fred: assuming you have the 2.2I4 since you replaced coil packs. you said "will crank over, but will fire"??? meaning it will spit and sputter, or not catch at all? as Blazer asked, what was the actual reading for fuel pressure? how was the truck running before? did it make a pop and quit? was fuel filter changed? i have seen where clogged filter will still give good pressure reading, but not enough fuel volume gets to engine.
@Andy: since you replaced cap and rotor, assumnig you have the 4.3V6. same kinds of questions. getting fuel? getting spark? how was it running before, any spits and sputters while cranking?
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
spray starting fluid into intake 2seconds worth no more , if it starts and then rapidly dies you have fuel problem this technic can be used on most gas engines as a quick way to determine if engine is gas starved.......
thread is almost 3 years old. please refrain from posting in old threads
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
