Old 01-07-2008, 06:06 PM   #1
gw84
gw84's Avatar
Send a message via MSN to gw84
code 43...knock sensor
I did a search, but apparently there's some problem with the database....so here's my question. CEL came on the other morning when I fired it up. Put my code key in and got a code 43, which according to the trusty Chilton is a knock sensor or knock sensor circuit. What does this mean? help!!
forgot to mention '93 3.1:
This ain't your grandma's car!!
gw84 is offline   Reply With Quote
Old 01-08-2008, 04:07 AM   #2
16th hippy
Re: code 43...knock sensor
either sensor is faulty, or a fault in wire. unlesss you have critter infestation or wires moved and got chafed/rubbed, is most likely sensor. check the wire visually, and if looks good, replace sensor.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
16th hippy is offline   Reply With Quote
