Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 11-07-2007, 11:04 PM
AlkalineProdigy AlkalineProdigy is offline
91 Berreta Rough Idle When Cold Before Closed Loop
Once it goes into closed loop it runs fine. First off the car sets no check engine light. So I took out the IAC vavle and put it back to default I reset the ecu by removing the battery cable. I took it ran it at between 35-40 so it would reset both the iac and ecu. But after a cool down it still has the rough idle. The fuel injector run runs a little rich and speradic before closed loop but again once it gets hot enough to go into closed loop it runs fine. Since its a 91 autozone or checker have the code checker for the computer but since its not showing the check engine light it might not even have any codes. Also I checked all the vacuum lines and they are all connected.
Old 11-09-2007, 11:23 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
Re: 91 Berreta Rough Idle When Cold Before Closed Loop
Datastream and bad O2 sensor...
Old 11-09-2007, 11:53 PM
What do you mean by datastream. Also shouldnt the O2 sensor not make a difference until the car is in closed loop. I thought that the ECU does take readings from anything other than the IAC untill it hits closed loop. Any help would be appreciated I really cant drive the car in the condition its in and this is my only car.
Old 11-10-2007, 12:41 AM
loosenut74's Avatar
sound like you have been talking to too many back yard mechanics...lol.. I meant take it somewhere do a datastream, and i'll bet you you also have a bad 02 sensor...
Old 11-10-2007, 12:21 PM
well my question is why would the o2 sensor not work properly in open loop and fine in closed loop. I read in the mitchells that the ecu doesnt read anything other than IAC valve while in open loop. But I will check it out thanks for your help
Old 11-10-2007, 06:00 PM
jsgold jsgold is offline
Just a couple of thoughts, are your plugs OK, wires, filters(air and fuel)? How about the intake hose on air box? One item is that maybe you have a weak coil pack on there and one plug may be firing weaker than rest. Possible injector problem too, but check your fire on each cylinder for a long 2" plus BLUE spark. If anything shorter than than you could have a weak one. Common problem. Again, just some thoughts...
I used to be indecisive, now I am not so sure.
Old 11-10-2007, 09:29 PM
Ill try all that and reply with what I find.
Old 11-17-2007, 02:10 AM
loosenut74's Avatar
find out anything yet?...
